tranny help
Old Nov 19, 2002 | 01:11 PM
Leets's Avatar
Default tranny help
Can someone please tell me why everytime I shift my tranny feels the need to jerk suddenly and make a loud "clunk" noise? Sorry if it's a dumb question, but I have minimal tranny knowledge, and it just doesn't strike me as normal.
Old Nov 19, 2002 | 10:35 PM
Leets's Avatar
Default Re: tranny help (Leets)
ttt
Old Nov 20, 2002 | 08:18 AM
1990hondaHF's Avatar
Did you check the fluid level? Also, a lot of people have said that when they use Honda MTF, shifting is A LOT easier.
Look here: https://honda-tech.com/zerothread?id=234398
Old Nov 20, 2002 | 11:26 AM
keithv's Avatar
Default Re: tranny help (1990hondaHF)
your motor mounts might be broken, so give them a look.
Old Nov 20, 2002 | 04:39 PM
SMech987's Avatar
like the other guy said check your trans. fluid. but sometimes you just cant fix the tranny and might need another one.
Old Nov 20, 2002 | 05:29 PM
red_honda_racer's Avatar
Default Re: tranny help (SMech987)
How hard do you shift in to gears? And how frequently? It might just be wear and tear and a bearing could be going out.
Old Nov 30, 2002 | 10:26 PM
skud_dusty's Avatar
its called a Honda Transmission. If you abuse them, they suck.
Old Nov 30, 2002 | 11:55 PM
Mista Bone's Avatar
D Tranny Guru
I'll bet the pinion shaft is on the way out.......
But what do I know?
Old Dec 1, 2002 | 07:40 AM
Kasper.'s Avatar
Default Re: tranny help (Mista Bone)
you say its like this in every gear?? well start with the easy **** first....when was the last time the clutch was replaced...
when it comes to defying the tranny or the clutch...and you can pinpoint it down to somthing happening in every gear you go for the clutch first....since what do you do everytime you change gears....you engage the clutch...
sounds to me more like a bad clutch disk and t/o bearing.....but if you do replace the clutch replace everything.
daniel990836
Oct 7, 2007 02:53 PM
Skipper75
19
Jan 30, 2007 11:00 AM
-Championship-
Jun 29, 2006 12:37 AM
f150harleytruck7
Jul 13, 2005 04:04 AM
Kazmans94cord
Apr 11, 2002 01:34 PM
