95 civic weird ideling
Old Nov 19, 2002 | 12:58 PM
tinascivic's Avatar
Default 95 civic weird ideling
when the engine is cold the idel goes up and down up and down until the engine warms up. could this be a thermostat problem?
Old Nov 19, 2002 | 01:45 PM
Turbo Powa's Avatar
Default Re: 95 civic weird ideling (tinascivic)
thats kinda funny. I have this integra in my driveway. Its a project car that I'm working on. It does the same exact thing. I have no clue what is wrong so i'd like to know this info too. I hope someone replies with something useful and please dont say its a vaccum leak cuz its not.
Old Nov 19, 2002 | 01:47 PM
black2kcivic's Avatar
Mine does it in the cold too, in fact so does just about every car that I have ever owned. I think its normal.
Old Nov 19, 2002 | 02:02 PM
TheKidd's Avatar
Default Re: 95 civic weird ideling (black2kcivic)
My car started doing that all the time wether it was warm or cold. There is a screw on the left side of the throttle body that you can adjust to alter the idle. Mine hasn't had the problem since.
Old Nov 19, 2002 | 02:04 PM
tinascivic's Avatar
Default Re: 95 civic weird ideling (Panda EK)
yeah i used to have an 88 integra too with the same problem before i sold it.
Old Nov 19, 2002 | 02:06 PM
after my car warms up I have no problem with it, the performance is unaffected.
Old Nov 19, 2002 | 02:44 PM
GREEN_CIVIC's Avatar
Its just ur Throttle body sucking in cold air warm air higher rpm (cold) lower rpm (warm) adjust ur throttle bottle cable very eazy to do.
Old Nov 19, 2002 | 02:55 PM
Turbo Powa's Avatar
Default Re: 95 civic weird ideling (GREEN_CIVIC)
Throttle bottle? Do you mean throttle body cable?
Old Nov 19, 2002 | 03:20 PM
-DeFtOnEs-'s Avatar
check your throttle position sensor!
Old Nov 19, 2002 | 03:44 PM
4doorB18Bcivic's Avatar
Default Re: 95 civic weird ideling (5ZigenSol)
The same thing happens to me, but after a few minutes it idles normal, if i adjust the throttle body would it not be screwed up when it starts to idle "normal".
Old Nov 19, 2002 | 05:15 PM
96civich22's Avatar
you engine is throwing a code check out your o2 sensor, cause i know with my civic when i installed my h23/h22head i didnt hook up the last o2 sensor and it did that same thing and then when i put it in it stopped doing the werid ideling. so check that out
Old Nov 19, 2002 | 06:35 PM
Turbo Powa's Avatar
Default Re: 95 civic weird ideling (96civich22)
I dont think the guys getting a CEL. I sure as hell aint gettin a CEL. Anyone else had this expierence before? If so, what was the cause and what did u do to fix it?
Old Nov 19, 2002 | 06:42 PM
schtozo's Avatar
my car did the same exact thing when i swapped it...
it did it like for two months then i took it to my friend to check it...
guess what!!! two sensors where inversed... i mean the two sensors at the back of the intake manifold where connected viseversa... after correction
jtwarrior14
Mar 17, 2015 12:40 PM
Lokisdope
Dec 3, 2007 01:44 PM
gritsak
Nov 25, 2002 03:36 PM
MetalKill
15
May 26, 2002 09:53 PM
