Koni Yellows w/ H & R Sport Springs
Old Nov 19, 2002 | 12:57 PM
paRRRker's Avatar
Default Koni Yellows w/ H & R Sport Springs
What are your thoughts on using Koni Yellows paired w/ H & R sport springs for my ITR?
Old Nov 19, 2002 | 01:24 PM
tecnic1's Avatar
Default Re: Koni Yellows w/ H & R Sport Springs (Hype-aaaRRRR)
works plenty good on my car.
Old Nov 20, 2002 | 01:07 PM
paRRRker's Avatar
Default Re: Koni Yellows w/ H & R Sport Springs (tecnic1)
aight thanks man, btw, does this particular setup give you a stiff ride like it improves handling alot or what? what do you think about using this setup for daily driving and then weekend autocrossing? thanks alot man
Old Nov 20, 2002 | 01:14 PM
uNF$@#!'s Avatar
first off, the #29502 provide linear rates.
second off you will notice the added spring rates.
this is only the 3rd thread about it this week..
Old Nov 20, 2002 | 01:15 PM
Dave-ROR's Avatar
Default Re: Koni Yellows w/ H & R Sport Springs (Soup ****)
actually, the 4th I believe
Old Nov 20, 2002 | 04:46 PM
tecnic1's Avatar
yes it is noticably stiffer, but I really am not too worried about it being to harsh on the street. I have nuts the size of a large elephunts and don't have time to bleed.
I liked the way it improved the feel of my car. It tends to understeer less. notice I stopped well short of saying it does not understeer. teh biggest improvemant was in high speed sweeper type turns, where I have found a very progressive transition to slight understeer. I also trail brake a lot when I autocross and have noticed the I did not lose much stability under straight line brakeing, but the car transitions to an oversteer sitiuation a lot more suddenly then it did on the stock springs. this setup absolutely 0wNz circle track though.
yes I daily drive and frequently autocross my car.
and yes, search will reveal much more information from people much more knowledgeable then myself, but I hoped I helped.
all of this is on azenis (40f, 41r) with front shocks 1/4 turn off full stiff and rears1/2 turn off full stiff
Old Nov 21, 2002 | 06:31 AM
paRRRker's Avatar
aight thanks alot man for all the information on this setup
Old Nov 21, 2002 | 06:32 AM
paRRRker's Avatar
btw, do you'll know if koni yellows off of an 00 ITR will fit my 98 ITR? thanks
Old Nov 21, 2002 | 01:41 PM
tecnic1's Avatar
yes...same P/N.
Old Nov 23, 2002 | 08:45 AM
paRRRker's Avatar
aight thanks man
Old Dec 2, 2002 | 03:42 PM
paRRRker's Avatar
what do you'll think about 1/2 turn from the stiffest on the front and 1/4 turn from the stiffest on the rear?
thanks
Old Dec 3, 2002 | 06:39 AM
paRRRker's Avatar
bump, somebody's gotta have some suggestions on this
thanks
Old Dec 3, 2002 | 07:27 AM
rodimus's Avatar
i have em.
now i want ground controls in place of my H & R's.
i would save a lil extra and just go that route.
chrisff521
Suspension & Brakes
24
Mar 24, 2010 01:21 PM
accordtuner1996
Aug 2, 2006 09:41 PM
Myh4tch
21
Jan 20, 2004 04:15 AM
Tweakmeister
Jan 2, 2003 08:46 PM
speedevo
Aug 31, 2002 05:13 AM
