Help w/ wire connectors in dash!!!
Old Nov 19, 2002 | 12:32 PM
.jacob's Avatar
Default Help w/ wire connectors in dash!!!
I am attempting to put my dash back in. When I plugged as many wire plugs and such as I could find into the corresponding plug (male/femal, and to the best of my knowledge) the car would not start, I got some lights in my cluser, none on the dash, no head lights or anything, engine won't start, but it does try to turn it over. I got a buzzing noise from the fuse box and a beeping noise. I found where most of the plugs went into but I couldn;'t find a good lot of the rest of them. Please help, pix would be greatly appreciated.
-Jake
Old Nov 19, 2002 | 12:39 PM
TurboBumblBee's Avatar
Default Re: Help w/ wire connectors in dash!!! (Chiller514)
all that we can do is say go back and look for what your missing.. you probably done have some plugs pluged into the fuse box or maybe the ecu.. check it out agian and start over
Old Nov 19, 2002 | 01:08 PM
92sleepR's Avatar
New User
Hmmmm. Without seeing it, it's virtually impossible to diagnose. Check everything over again. You can't be too **** about things like this. When I stripped / re-installed the dash in my current CX project i labeled absolutely every last connector.
Where are you at? I could possibly stop by next weekend to have a look if you cant get it fixed before then. I'm becoming something of an expert on the EG civic wiring.
Mike
Old Nov 20, 2002 | 03:37 PM
.jacob's Avatar
Default Re: Help w/ wire connectors in dash!!! (92sleepR)
I live in Vienna, a buzzing noise came from my fuse box! I'll IM or PM u, my AIM SN is Chiller514
Thanks man,
Jake
Old Nov 20, 2002 | 05:31 PM
Turbo Powa's Avatar
do yourself a favor and get a repair manual. Look up the wire diagrams mang!!
Old Nov 21, 2002 | 05:20 AM
.jacob's Avatar
Default Re: Help w/ wire connectors in dash!!! (Panda EK)
I have the Helms manual...I just need to know which connectors go where.
Old Nov 21, 2002 | 04:17 PM
Turbo Powa's Avatar
which connectors are you referring to? I just tore my hole dash today so I can amber my bulbs, didnt come out to great but I'm going to try a different technique next time.
mac_24_seven
Mar 13, 2012 03:34 AM
codyellis
Apr 5, 2010 08:10 AM
ajason24
16
May 9, 2009 02:27 PM
kelviiv
Apr 12, 2008 12:11 AM
hugo7
Nov 3, 2005 06:02 PM
