Dash grounds?
Old Apr 5, 2010 | 12:11 AM
codyellis's Avatar
Default Dash grounds?
Where does the dash wiring ground to? Whats the ground directly behind the cigarette lighter go to? Its a 12mm bolt that bolts to the dash support bars.
Old Apr 5, 2010 | 03:07 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Dash grounds?
I think that's just the general dash harness ground. Otherwise it probably grounds through the fuse box. I've had my dash off a couple of times, and the only wires I had to disconnect were the plugs on the fuse panel and that one ground wire.
Old Apr 5, 2010 | 05:47 AM
JDM 98 GSR's Avatar
i believe that 12mm one is the dash ground
Old Apr 5, 2010 | 08:10 AM
codyellis's Avatar
When I pulled my dash out I saw that wire was cut. Where should I look for that wire?
mdakatkr
Honda Civic (2006 - 2015)
Oct 16, 2006 07:59 PM
juka
Feb 10, 2006 08:51 AM
dk127
Apr 19, 2004 11:17 PM
