D16y8 p28 questions
Old Feb 25, 2025 | 06:11 PM
Job_Turkey's Avatar
Default D16y8 p28 questions
Bought a d16y8 for my 96 civic hatch, put a p28 and d15b7 dizzy. Car cranks, but no start. Injectors throw too much gas, and it drowns the car and I have to turn to push out gas. Using stock obd2 injectors, and they plug right in. Got it chipped. Doesn’t have plug for crank sensor by the crank pulley, but I got an adapter that plugs into the obd1 dizzy which should theoretically work as a crank sensor. Anyone have any suggestions or ideas on what I could do to fix the issue?
Old Feb 25, 2025 | 07:24 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: D16y8 p28 questions
Are you using Y8 or Y7 fuel injectors ? Is your ECU conversion harness correct ? Are your plug wires in the proper position/firing order ? When you say "Doesn’t have plug for crank sensor by the crank pulley", what EXACTLY do you mean ? A D16Y8 engine should have the plug on it and a '96 Civic engine harness should have a plug in the same area that connects to the engine. Fortunately, an OBD-1 P28 doesn't NEED (or even recognize) that sensor, so you don't have to worry about it at all. The three sensors that you need will all be found inside the distributor. Just curious... WHY aren't you using a Y8 distributor that plugs right into the engine harness ?
Old Feb 25, 2025 | 07:46 PM
Job_Turkey's Avatar
pretty much, swapped back to y7 injectors, since the old distributor wasn’t sending fuel from the injectors. Maybe I’ll switch back to the y8 injectors, now that they’re getting signal, but it still shouldn’t fire that much fuel in anyways. Using the obd1 dizzy, since the obd2 doesn’t have the crank sensor build into the dizzy. Also I got a jaxkspania harness, and none of them come with the plug for the crank by the pulley
Old Feb 26, 2025 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
1992-95 OBD-1 and 1996-98 OBD-2 distributors are the SAME inside... only the plug style is different. The sensor you are referring to is a Crankshaft Fluctuation Sensor... which for OBD-2 "D" series engines, is in addition to the Crank Position Sensor that is found inside the distributor. The OBD-1 ECU only needs the three sensors inside the distributor (TDC, CKP, CYP) to run the engine properly. The OBD-2 ECU looks for FOUR sensors: (TDC, CKP, CYP, and CKF).
The distributor has nothing to do with fueling... only spark. If you are having trouble getting the engine to run, I would be looking at the garbage engine harness that you purchased. They are notoriously suspect.
Old Feb 27, 2025 | 08:26 AM
Job_Turkey's Avatar
any recommendations for a good harness, one that doesn’t break the bank either😭
Old Feb 27, 2025 | 07:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If it was my car, I would have used the original '96 hatch engine harness and modified it to fit the replacement engine. If you don't have the original engine harness, one from a '96-98 Civic with the same trim level (CX, DX, LX) works as well. Moving a few wires, lengthening a couple of plugs, and swapping a clip or two is really no big deal.
Old Feb 28, 2025 | 09:09 PM
Job_Turkey's Avatar
Finally got to the car, swapped back to the y8 injectors, and changed a ripped o ring and the car started completely fine. Y7 injector must’ve just been fried cuz it stayed open completely. Car started, just gotta do some minor adjustments and fix the coolant pipe leak, and I’m set to drive home😊
Old Mar 1, 2025 | 07:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Great to hear that you got her going... congrats.
Old Mar 1, 2025 | 07:45 PM
Job_Turkey's Avatar
thanks man, **** was just bugging, but I’m almost done, just needed a bolt for the torque mount and we should be good to go by tonight
Job_Turkey
Feb 18, 2025 12:44 PM
Ronnie254
May 30, 2017 02:28 PM
dosstraflamus
Engine Management and Tuning
Nov 24, 2014 07:31 AM
honda_turbo
Apr 2, 2006 09:43 AM
willyboyK20
Jan 29, 2002 05:03 PM
