chipped p28 on a D16y8
Old Jan 29, 2002 | 05:12 AM
willyboyK20's Avatar
Default chipped p28 on a D16y8
I did a search but i did not find what i was looking for. I wanted to know would running a chipped p28 for sohc specs on a D16y8 with i/h/e and a cam be worth while or should I just save up for something bigger(ie. swap,turbo). Has anyone done this before on their D16y8, if so how much power did u gain.
thanks in advance.
Old Jan 29, 2002 | 07:44 AM
eg6ajk's Avatar
Default Re: chipped p28 on a D16y8 (willyboyD16)
it all depends, as far as my setup, i gained about 10whp + 7lb/ft of torque, on my D15b sohc vtec from a chipped ecu (gains are from 4000rpm on), low end lost some power, but then again you can use a switch and have a stock and race program on the same ecu
Old Jan 29, 2002 | 09:43 AM
rainforest's Avatar
Default Re: chipped p28 on a D16y8 (eg6ajk)
well if you just got the p28 and converted to obd1 you would allready have a obd1 conversion when you got a swap. and you wont have to worry about all the extra emissions crap.
Old Jan 29, 2002 | 11:09 AM
Default Re: chipped p28 on a D16y8 (rainforest)
I already have the D16y8 in a 97 civic ex. I was thinking about changing out the obd2 ecu for a chipped obd1 because with those they are easier to put a chip in and i would'nt have to get the piggy back computers to fine tune my car. U can also raise the rev limits and take out speed gov, which u can't do with the piggy backs. It just seems like a better package to me
Old Jan 29, 2002 | 05:03 PM
M.A.R.C.'s Avatar
yes but remember to run the obd1 ecu in your car you'd also need an obd2->obd1 adapter which is like $250... either that or have someone rewire the damn thing for you which would end up costing close to that anyway.
Alicali
Aug 18, 2017 08:03 AM
lil4cl
Engine Management and Tuning
Jun 30, 2010 02:42 PM
madsci
11
Mar 10, 2010 08:45 PM
honda_turbo
Apr 2, 2006 09:43 AM
JH4DC231
Aug 17, 2005 11:46 PM
