1996 Civic - Sporadic stalling when easing clutch
Old Jan 15, 2025 | 10:28 AM
Embemor's Avatar
Default 1996 Civic - Sporadic stalling when easing clutch
Hello,
I have a 1996 Civic Hatchback. Manual Transmission
The car jerks then stalls about 60% of the time when going from neutral to first and first to second. (feels like I'm a new driver learning how to work a clutch) The clutch doesn't seem to be slipping at all.
It had a similar issue last year with jerking from a stop which was determined to be an over-stretched throttle cable. That cable was replaced and problem resolved. The difference is that now it actually stalls.
I have noticed that the speedometer has stopped working recently - could these symptoms be related? (bad VSS maybe?)
I'm stumped. Any thoughts and suggestions appreciated.
Thanks,
Dave
Old Jan 24, 2025 | 05:04 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: 1996 Civic - Sporadic stalling when easing clutch
Bad VSS won’t affect your drivability. Sounds like your clutch slave cylinder is going out or the clutch pedal needs adjusted
Old Jan 27, 2025 | 05:26 PM
Embemor's Avatar
Thanks, NVturbo. I;ll check that out.
Cheers,
Dave
EFjoe91
23
Jun 9, 2014 04:40 AM
cutlass68
Transmission & Drivetrain
Mar 25, 2010 10:13 PM
''Simon''
17
May 23, 2008 04:28 PM
Itu
May 18, 2006 11:06 AM
