Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
2001 Civic EX oil overflows into breather intake
Old Dec 26, 2024 | 06:38 AM
bmarsh2610's Avatar
Default 2001 Civic EX oil overflows into breather intake
I have a 2001 Honda Civic with V-Tech which has been stored in the garage for about two years. I went to start it and noticed that the engine ran really rough. After replacing the cam and crank sensor, 02 sensors, MAF, and fuel pump I noticed that within a minute to two minutes it engine oil would fill up the whole valve cover and flow into the Throttle body. I remove the valve cover and ran a long ride all the way down to the oil pan to make sure there were no obstruction. Please help
Old Dec 27, 2024 | 04:29 PM
benchwarmer's Avatar
5 Year Member
Default Re: 2001 Civic EX oil overflows into breather intake
I would start with a compression test and basic inspection of the motor , After 2 years the gas is no good and shouldn't have been ran with it . Things should be tested before buying parts you don't need
Oscarperez99
11
Feb 7, 2018 08:45 AM
Civiccity03
Jul 17, 2017 04:54 PM
christin
Dec 12, 2006 09:56 AM
2lude4u
Jul 11, 2005 09:55 PM
