What are the torque specs for upper control arm bushings?
I searched online but couldn't find any information specific to my 1990 Civic. Does anyone know the torque specs for the bushing bolts?
Thanks
Thanks
First and foremost, I am and will not be responsible for damages or disrepair. But according to FSMs 29-35ft-lbs. According to Haynes 32ft-lbs. Not trying to sound rude but invest in a Haynes Repair Manual.
Which upper control arm, front or rear? I only have quick access to the DA integra FSM which should be similar. Front UCA bolt that goes through the bushings: 22 lb-ft. The nut that passes through your shock tower and secures the whole UCA to the chassis: 47 lb-ft. Rear UCA bolt through the bushing: 40 lb-ft. Rear UCA bolts that secure the arm to the chassis: 29 lb-ft.
2016Civic
Honda Civic (2016 - Current)
Jun 21, 2022 08:18 AM
