Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
D17A1 Rebuild
Old Dec 11, 2024 | 02:55 PM
anxto150's Avatar
Default D17A1 Rebuild
Hi all,
Have an ‘05 VP that I am currently doing a full rebuild on. (Car burned oil and finally blew the head gasket.)
I already pulled the engine, sent it to the machine shop and got it back. (Block and Head Resurfaced, Crank Polished).
I bought all the parts for this rebuild and have been receiving them little by little. I got my head bolts in today and the newer ones seemed significantly longer than my older ones. Which led me to realize some of my older ones are actually different sizes.
Do I have the right head bolts? (MAHLE GS33750 10x140mm). Or could my car have the incorrect ones from the start? (I’ve known the previous owner for many years. He told me he had replaced the head gasket a few years ago and is the type to cut cost on this sort of thing.)
If I do have the wrong ones, which should I buy?
TIA!
(in the attached images, one is of all of my old head bolts, and the other is of the new (far left) and 2 old which are different sizes)
Old Dec 13, 2024 | 04:51 AM
benchwarmer's Avatar
5 Year Member
Default Re: D17A1 Rebuild
Buy honda parts or OEM equivalent , check everything and do research till you're absolutely sure you have the correct parts
Old Dec 15, 2024 | 06:02 AM
theYBLEGAL's Avatar
Loved
99% sure the lengths are listed in the description with the part numbers https://dreamshop.honda.com/s/
https://dreamshop.honda.com/s/category/honda/0ZG6g0000004HolGAE
Bolt-washer (10X140) (SAGA)
Part Number: 90005-PM3-003
MSRP : $10.39
Looks like all of them should be 140mm long
Prune
Sep 21, 2023 01:45 PM
Logan L.
Engine Machining & Assembly
Jun 9, 2019 04:55 AM
Ash J. Williams
Jun 20, 2011 10:56 PM
alfee
Mar 29, 2009 08:39 AM
austincrx
Sep 7, 2006 09:49 AM
