I need help from some Canadians
Old Dec 11, 2024 | 06:31 AM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Default I need help from some Canadians
I want to be able to provide aftermarket replacement ICUs for Canadians. I need help from owners of fourth gen Canadian Civics. I have found a discrepancy between the Canadian wire diagram in the Honda Service Manual and the actual cars sold in Canada. I have only have a sample set of two, but neither car matched the diagram in the Service Manual. I need to increase the size of my sample set so I can be confident that the ICUs will interface correctly with Canadian Civics.
You don’t need to take anything apart; I just need a picture like this one of the connector at the ICU.
You can pretty easily take a picture like this using the front facing camera on your cell phone. Here is a YouTube video showing how I took this picture.
If I could get a sample set of 15 or 20 different Canadian Civics I would feel a lot more confident in my conclusion that the Service Manual is incorrect.
The connector can handle up to 10 wires, the question is; Do pins 6 and 7 have wires connected to them or not? The service manual says there are wires. There is always a GRN/BLK wire at pin 4, pin 5 is always empty. Pin 6 & 7 are the positions in question. The wire diagram says 6 is connected to a GRN/RED wire and 7 is connected to a GRN/WHT wire. Here is a picture of one actual Canadian connector. (In this picture the clip is on the reverse side)
As you can see there are no connections to 6 or 7. If you can’t take the picture or it is too difficult to post the picture, it would still be helpful if you could tell me whether or not those wires exist on your fourth gen Canadian Civic. I put a bit more faith in a picture but any input would be helpful.
I can simplify the question further. If there is a wire coming out of either one of the two holes directly behind the clip (5 or 6) then it matches the Service Manual. If neither of the two holes behind the clip have a wire then it matches the other Canadian Civics I have seen. This way you don’t need to know what number hole it is because hole 5 will never have a wire so if either one of the two holes behind the clip has a wire it is hole 6. Because 6 is for the left and 7 is for the right there would never be a case where a wire exists in 6 but not 7 so I don’t actually need to confirm if there is a wire in hole 7.
What I really wish I could get is some sort of official documentation that confirms the error in the Service Manual.
Old Dec 11, 2024 | 06:36 PM
Caoboy's Avatar
-Intl Steve Krew
Community Influencer
Active Streak: 120 Days
Loved
Default Re: I need help from some Canadians
@CAN97SH might have some friends that can help you out.
Keep up your research!
Old Dec 12, 2024 | 06:15 AM
CAN97SH's Avatar
Resident Hoser #1
Community Builder
Danm that is an oldie gen! My brothers have newer models. My best suggestion would be to join a Canadian honda forum to ask there.
I've asked my brothers to see if they know anyone who has a 4th gen
Buddy does have a CRX. Maybe that would help?
Old Dec 12, 2024 | 07:37 AM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Yes, CRX, Civic and Wagon from 1988 thru 1991 should all be compatible with the same ICU in Canada. Can you point me to a Canadian Honda forum?
Thanks!
Old Dec 12, 2024 | 10:00 AM
Maxcapacity's Avatar
I'm Canadian, I'll take a pic of my CRX plug later and post it for you.
Old Dec 12, 2024 | 08:32 PM
It was a slightly difficult getting the pic as the car is tucked away for the winter.. The pic is from my '89 CRX si. Hope that helps
Old Dec 12, 2024 | 10:52 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
That picture is perfect! If that is a CRX built for the Canadian market (not a US car imported to Canada) then, that one picture is all I need to prove that Canadian CRXs and Civics are NOT all wired the same way at the ICU, which is disappointing to me because it means I need to somehow know which version of the wiring a person has before I can get them a compatible ICU.
Do you happen to remember/know how your front corner lights behave? Do they blink with the turn signals or not? I'm looking for an easy way to recognize/determine which way the ICU is wired up in each car. Which of these stickers is on your CRX?
Old Dec 13, 2024 | 08:55 AM
Yes it's a Canadian car. I do not have a sticker but still similar have a metal tag riveted on. Nothing that would be helpful to you though.
The coner lights beside the headlights do not blink with the turn signals, just the lower front face bumper lights.
Sorta dumb that they did that so I wired in CRX si-r side marker lights in the fenders that are wire tapped into the front face bumper lights so not to get in an accident because originally you can't see from they side for oncoming vehicles..
Old Dec 13, 2024 | 12:07 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Thank you very much. That's all the help I need at this point. I now know what I have to do to make them compatible with all Canadian cars.
Blueallie
Aug 26, 2006 06:31 PM
GsR-Freak
Jan 12, 2005 10:35 PM
T25 civic
Oct 6, 2002 02:11 PM
c1civic
Sep 16, 2002 11:54 AM
austrian type-R
Dec 29, 2001 05:04 AM
