Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
2009 Accord Limp Mode
Old Dec 8, 2024 | 03:05 PM
Staged206K's Avatar
10 Year Member
Default 2009 Accord Limp Mode
I have 2009 Accord 2.4L that's in limp mode. I haven't checked codes yet. Last week I went to the store and everything was fine, it was 20F and windy though. I went to return and it took a long time to start, it seemed like it cranked for a long time but it started. The engine light popped on and a AVS/ACC/ABS light. I drove it home and it was surging above 3000 rpm. I thought the VTec solenoid screen became clogged and kicked the codes. I've seen that before on early model accords and replaced the VTec actuator/screen to fix. I reset the codes by unhooking the battery. The AVS/ACC/ABS light turned off but the engine light stays on. The car doesn't go above 2500/3000 rpm now, so it's in limp mode. I have a replacement starter from 2 years ago and have read that this might cause the issue with it being in limp mode. I will have to drive the car to Autozone in limp mode to check codes. Is it okay to drive in limp mod?. I was also thinking about buying a code reader from Amazon. Which is a good one to get? Thanks
Old Apr 10, 2025 | 01:51 PM
Staged206K's Avatar
10 Year Member
Default Re: 2009 Accord Limp Mode
Update -changed oil, tried reset by disconnecting battery, but it still had the flashing engine light after restart. I bought a code reader. Code 0301,0302,0300 - misfiring cylinders, I tired clearing codes, but they came back right away. I checked coil and cleaned injectors; cleared codes, but the flashing engine light came on again and hade same codes. I read posts about issues using a replacement starter causing these same codes to pop up. I put in a replacement starter 2 years ago. The suggestion was to relearn the curve for the crank sensor. Well, you need a special scan tool for $180 or have a service place do it for $350.I bought the Foxwell NT510 for Honda and went through the process to relearn the crank sensor curve. I had to do it a few times, but it finally killed the LIMP mode issue. I've been driving the car for the past 4 weeks with no issues. I thought I'd update the thread just in case someone needs some help with same issue.
Old Apr 22, 2025 | 05:51 PM
shmcg's Avatar
Does it have an aftermarket starter?
I had an issue with the same presentation. I got codes P0339, P0300, P0301, P0302. It had an aftermarket starter in it.
Relearning the crankshaft position sensor with the appropriate scan tool worked as a band-aid fix. Sometimes it would work for a weeks, sometimes just for a few days.
I eventually swapped the starter with an OEM starter and it completely resolved the issue.
Old Aug 30, 2025 | 09:58 AM
Staged206K's Avatar
10 Year Member
Yes, replacement starter. It's starting to kick codes again, but not going in limp mode. Car runs a little funny, but very drivable. I guess it's time to get a OEM starter or another replacement and gamble on 2-3 more years before issues show again.
markerickson200
Jan 25, 2019 02:51 PM
awb594
Jul 2, 2012 10:08 AM
jusdoit302003
Jan 18, 2011 11:07 AM
shortlid
Mar 15, 2006 05:04 PM
jagged4698
Mar 29, 2004 01:03 PM
