Power Windows
Old Nov 19, 2002 | 08:33 AM
James's Avatar
Default Power Windows
Hi I got an used 1988 Honda accord 4 door sedan. Power windows on all four doors except for the driver side are working fine. I checked fuse on engine compartment for the front left power window and it is fine. The one switch will not do anything on all windows or driver side window. What should I check into? A fuse box under the driver seat? Or driver side window motor? Or ...
Thanks
Jim
Old Nov 19, 2002 | 08:35 AM
urbanlegend21's Avatar
New User
Default Re: Power Windows (James)
does it click like it wants to work?
Old Nov 19, 2002 | 08:38 AM
James's Avatar
Default Re: Power Windows (urbanlegend21)
no, none at all.
Old Nov 19, 2002 | 08:41 AM
Desslok's Avatar
Is it plugged in? Is there a "window lock" switch?
Old Nov 19, 2002 | 08:44 AM
Stew Pidasso's Avatar
Probably the regulator...view this to change it. http://3geez.com/showthread.php?s=58...85&threadid=66
Old Nov 19, 2002 | 02:24 PM
Chiovnidca's Avatar
Three possible problems are...... The motor, the switch, and the p/w control unit.
Old Nov 20, 2002 | 12:26 PM
PnX-R's Avatar
I would have to guess the switch.. Because according to a Generic Wiring Diagram.. It seems as if all the Window switches are connected to the Master Switch.. And since the only switch that isn't working is the Master Switch, it could be the problem..
That's just what I think.. Good Luck.
USA
Oct 2, 2021 03:13 PM
kptrk06
Honda Civic (2001 - 2005)
Jun 29, 2014 09:26 PM
brad3266
Mar 19, 2014 08:53 AM
pvtkistlere1
Sep 15, 2010 06:00 PM
s4325
Aug 4, 2010 09:31 PM
