Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Crank but no spark
Old Oct 16, 2024 | 02:43 AM
Hyndan's Avatar
Default Crank but no spark
So my Civic EP1 has been dead for over a month now. It silently died while parking and won't start again. Turns over just fine, but never starts. No CEL or codes with OBD reader. And yes, the CEL light is working...
- Fuel pump & pressure OK and I'm getting fuel to the spark plugs.
- Checked all relevant fuses.
- Checked voltage and ground at each and every ignition coil. Brand new coils and plugs.
- Checked timing and replaced crankshaft sensor while I was in there. No difference.
- Immobilizer seems OK according to the dashboard symbol.
Any tips? I'm lost.
Old Nov 2, 2024 | 04:56 AM
benchwarmer's Avatar
5 Year Member
Default Re: Crank but no spark
What was the fuel pressure ? You said you checked it
Old Nov 12, 2024 | 08:59 PM
Hyndan's Avatar
It was around 40 psi, as it should be. The car isn't producing any spark - using starter fluid while cranking does nothing at all.
Old Nov 13, 2024 | 04:21 AM
5 Year Member
If you check for injector pulse and there's none it could be a bad crank sensor . I got one from nipa that lasted a week
DjShotokan
Honda CR-V & Element
Jan 4, 2023 01:16 PM
em1gbray123
20
Jun 30, 2020 02:28 PM
MRQ
Honda Civic (2006 - 2015)
Jun 9, 2019 05:48 AM
theschweizer
Feb 7, 2016 02:17 PM
Jeremy087
Jan 6, 2016 08:53 PM
