Drove home and now no start/no ecu power
Old Oct 11, 2024 | 02:09 PM
Eyescream413's Avatar
Default Drove home and now no start/no ecu power
I drove my car to IFO in NH on the 30th. About a 2 hour drive each way. Drove the car an hour each way to go out to eat in Connecticut a few days later. The following day drove a half hour each way. Again, zero issue. I went to move the car and it wouldn’t start. Ok, no problem, the signal wire must of came loose from the starter. That was fine. The starter is new. I checked it with jumper cables and a fresh battery with it out of the car. Checked all of my grounds. Pulled my s300 for a known working ecu. Why do I have no power to the ecu after the car had been functioning perfectly? I’m stumped. Any help? All of the fuses are good as well.
Old Oct 11, 2024 | 03:44 PM
GeoMetry's Avatar
Loved
Community Favorite
10 Year Member
Default Re: Drove home and now no start/no ecu power
If it has a manual transmission, check the little plastic plug that pushes the clutch interlock switch.
Old Oct 11, 2024 | 05:41 PM
i have the clutch interlock switch bypassed to rule that out as an option.
Old Oct 11, 2024 | 08:22 PM
PewterCam's Avatar
Main relay possibly?
97accordidiot
Jul 5, 2014 12:25 PM
Thizzed Out
Apr 3, 2009 03:35 PM
CBURKE
Apr 25, 2006 12:36 PM
B18C1EKhb
May 2, 2005 03:25 AM
spyz34
Mar 20, 2005 12:49 PM
