Won't start issue (kinda weird)
Hello all. Long time listener, first time call.... oh wait. I have a 89 Honda Civic LX. I had the timing belt break when I was turning a corner. Was only doing about 3 miles an hour, and believe it or not, I think I got majorly lucky. I replaced the belt, and put everything back together. Car started fine at first and purred like a brand new kitten. I then heard something I guess you could describe as grinding. The tension pulley nut for the compressor, wasn't tightened enough, and came off, as the pulley went cockeyed. I immediately turned the car off and checked to see the crooked pulley with no nut. I decided to eliminate the compressor to see if the car was good since the timing belt incident. It again tried to start just fine, but I heard another "clunk" (which I believe was the little cover of the pulley being thrown out of the engine well) to which I immediately shut it off again. When I tried to start again, it cranks just fine but just will not fire. I have no clue what happened and I thought I'd throw this up here and see if anyone had any ideas. Did a pretty throurough check around the engine, distributor, pulleys, starter, and pump. Saw nothing that looked bad/broken/out of place. If I can gleen some thoughts from you all, I'd be grateful. If not, then I still thank you all for your time. By the way, this is my first Honda, and am a car DIY guy, but not yet a Honda guy.
I have confirmed the crank and cam are turning, and I believe this confirms my belt is not broken (again).
When you reinstalled the timing cover and harmonic balancer, did you make sure you reinstalled the woodruff key? It's a little metal piece that makes sure the crankshaft timing gear doesn't slip. If it's missing, it'll slowly slip and kill your timing.
slowsinglecam
11
Dec 24, 2011 07:59 AM
pinoyboy204
Mar 2, 2010 06:21 AM
darkstoner420
Jan 14, 2010 06:58 AM
