D16z6 build questions
Old Sep 19, 2024 | 02:16 PM
AndrewP07's Avatar
Icon5 D16z6 build questions
I have a 1993 del sol si with an aftermarket exhaust and suspension. I want to know what the easiest and cheapest performance upgrades are. I dont want to run 8 second quarter miles, I just want it to be somewhat quick, and not compromise the reliability. Might turbo in the future if I dont have an eg or ek hatch by the time I want more speed. It will eventually just be a weekend cruiser, and not a track car. Thanks
Old Sep 20, 2024 | 01:19 PM
Maxcapacity's Avatar
Default Re: D16z6 build questions
To help make it somewhat quick, you could probably find a used jackson racing supercharger for maybe $1000 or less. Run 7psi for reliability.
Just need some bigger saturated injectors, 550cc or smaller and a good tuner. You have the good chip/tune-able P28 ecu already so not a whole lot needed. Maybe under 2k and you could be rippin it up. A good turbo set up will cost more.
Any bolt-ons will not satisfy and are minimal gains.. If you want some more go power, the supercharger is probably your best bet.
Old Sep 20, 2024 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Yeah, you have the cheap stuff already. The JRSC will be a decent bump if you can find a complete, solid kit. You will not need really big fuel injectors since you will only be adding about 45 or 50 wheel HP (do NOT use RC 550's with a JRSC... other brands in that size would be acceptable). You can even use the stock fuel injectors (or for a bit of additional safety, use a set of '97-01 Prelude fuel injectors). Tunable engine management will be required.
encrypted
Dec 8, 2021 05:07 AM
olish79
Jun 23, 2015 03:28 AM
osbunjosh
22
Dec 23, 2011 01:33 AM
shock.top.pat!
12
Apr 26, 2011 09:33 AM
Keewun
11
Jan 7, 2005 11:58 AM
