b16z6 cyl 3 no compression
Old Aug 29, 2024 | 06:30 PM
Hondariff's Avatar
Default b16z6 cyl 3 no compression
Hello Hondaheads, newbie here.
I hate to start with a question but here we go.
I have a manual 95 Civic with a b16z6/PO8-5 head. One day it started to run rough... cylinder 3 lost compression but the other three are good and even at around 170 psi with engine cold.
So, I did a leak-down test and cylinders 1, 2 and 4 are good within the green on the gauge but when I test cyl 3 it has a major air leak. the thing is that it leaks air to cylinders 2 and 1, very little to crank case, exhaust and intake (throttle wide open), or so I felt.
The test was performed at TDC on each cylinder with the crankshaft kept from turning. I'd think if it was the head gasket, cylinders 2&1 would leak back to cylinder 3, right? Or if it was a valve it would leak more through exhaust/intake.
Anyway, I did some wrenching in my younger days, mostly on 4x4 Toyotas. Did a couple of head gaskets, the problems were obvious. But, I'm not a professional by any means.
I'll start to take the head off but I was hoping there's somebody that is more familiar and has had the same problem that could give me some tips. I'd appreciate that a lot.
Old Sep 1, 2024 | 05:53 AM
NVturbo's Avatar
O.G. triple O.G.
Default Re: b16z6 cyl 3 no compression
Bent valve(s). Remove and replace and hope nothing else is damaged
Old Sep 1, 2024 | 04:14 PM
Hondariff's Avatar
I pulled the head off and it turns out it is a burnt exhaust valve, I'd post a picture but I still can't. Did not make sense but I was probably overthinking it.
Anyway, I appreciate your help.
zerovandez
Oct 3, 2011 05:38 PM
boosted_lude
Jan 27, 2006 09:31 AM
thehondaguru
Jun 24, 2003 07:41 AM
B18EG6
Nov 18, 2002 08:54 AM
