P0505 fluctuating idle
Old Aug 21, 2024 | 10:23 PM
61ragtop's Avatar
Default P0505 fluctuating idle
Hey guys! Here is the background on the car. We just put a rebuilt d16y8 in my son’s 99 coupe. At that time we also did a manual swap. The intake swapped to a manual intake and we did the 3 to 2 wire conversion. I am not aware of where the intake/throttle body came from. But we had to do the air injection delete on it.
We did a short startup last night and it seemed fine. After buttoning things up today we went to run it to check timing coolant etc and the rpm with no load at idle will fluctuate from 7-800rpm to about 23-2500rpm. It threw the p0505 code as well. I hope I have all the info if not ask away.
Old Aug 25, 2024 | 05:04 AM
youstolemybeer's Avatar
5 Year Member
Default Re: P0505 fluctuating idle
clean the IAC valve, rebleed the coolant system
nmat092703
Jul 9, 2024 09:23 PM
Dmasso
Jul 29, 2021 12:55 PM
bless341
Apr 21, 2010 05:16 AM
AZNracerx1989
Dec 14, 2005 12:01 AM
