Honda S2000 Honda S2000
My S2KAP2
Old Jul 6, 2024 | 03:52 PM
JimyJakJr's Avatar
Default My S2KAP2
I need help. Ive melted my Vtech oil psi switch one too many times. I want to delete and bypass the wiring or whatever. Cant seem to get any solid info. Need help plz
Old Jul 6, 2024 | 09:31 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: My S2KAP2
Get rid of the turbo kit. Purchase a Kraftwerks Supercharger kit, make 450 wheel HP and move on. Then and only then will you stop melting parts and wiring. It is a wonder your fuse box hasn't turned into a Salvador Dali painting yet.
Old Jul 7, 2024 | 08:22 AM
JimyJakJr's Avatar
Yeah not doing that. Im pushing close to 600 to the wheels. I dont want to go back. Ive already tucked my wiring and moved my battery and fuse box. Not going to drop another 6k for just a $40 sensor.
Old Jul 7, 2024 | 10:02 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I understand. Your engine bay looks awesome and nearly 600 wheel HP is pretty intoxicating. What engine management are you running ? Almost all that I can think of offer the ability to turn off, and thus delete, the VTEC Oil Pressure Switch in the calibration. Doing this, you could then remove the oil pressure switch and never have to worry about it again. RyWire offers a Titanium bolt that seals the threaded hole in place of the oil pressure switch for cheap... like $12.
Old Jul 8, 2024 | 05:41 AM
Ryanthegreat1's Avatar
Titanium/stainless heat shield and some thermal sleeve on the harness large enough to slip over the plug?
Old Jul 8, 2024 | 05:54 AM
JimyJakJr's Avatar
Well I've sleeved it too. No way to get a heat shield of just the switch. My header pipe to close. Tks tho.
Old Jul 8, 2024 | 05:57 AM
JimyJakJr's Avatar
Here is the bolt
Also insulated my cooler hoses. And ive used this same sleeve to cover the switch.
Old Jul 8, 2024 | 08:52 AM
It's just a pressure switch. Hard line out of the VTEC solenoid past the hot parts and remote mount the pressure sensor.
Old Jul 8, 2024 | 11:14 AM
JimyJakJr's Avatar
Thats not a bad idea. Tks!! I just may do that! Im gonna try if i can switch it on my tuner first. But that is a solid option. Tks brother!
Old Jul 8, 2024 | 12:00 PM
spAdam's Avatar
Loved
Community Favorite
Delete it and shut it off in the calibration. Pretty standard practice for anything with a VTP switch.
Old Jul 8, 2024 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
If you already have the bolt that replaces the VTEC pressure switch, what am I missing ?
That's what I said.
slo88hatch
Honda CR-V & Element
Nov 7, 2016 06:05 PM
b16integ
May 9, 2005 09:49 AM
btole
May 24, 2003 03:50 PM
JDMTEG98
Sep 1, 2002 07:04 AM
