Need Advice On 2002 CR-V Valve Adjustment
I'm going to adjust the valves this weekend on my 2002 CR-V. How are the cylinders numbered, what is the firing order and do any of you have any tips, tricks or words of wisdom to offer? Is there a write-up on this site that describes which valves can be adjusted at the same time as the crank is rotated manually? This will be my first experience on the 2.4 and depending on the engine, sometimes multiple valves from different cylinders can be adjusted at a given crank position to save some time... Thanks in advance!
