Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
Strange problem with clutch | Help needed!!
Old Jun 7, 2024 | 11:39 AM
Tr3vorX's Avatar
Default Strange problem with clutch | Help needed!!
I regently purchased a 2007 Accord EX-L w/ 6 speed gearbox. I noticed the clutch was slipping in all all gears, most noticeable in higher gears under heavy throttle, but bought it anyways planning to replace the clutch eventually. A few days after buying it, I started having an issue where if I sat with the car running wirh the clutch pedal depressed for an extended period of time, It would end up sticking to the floor, and i would have to pull it back up and then it would function normally again, until last night. Same as the other times the pedal stuck to the floor, but this time when I pulled it back up it didn't rebuild pressure. It's now acting as if there's a bunch of air in the system. I have tried rebleeding with no luck.
Here's the strange part, and this may turn out to be somthing normal, but it's strange to me.. I started thinking the pressure plate my be stuck in some way so with the car in gear, I basicly turned the key and stared the car in gear.. I gave it the beans a few times to see if that might resolve my issue in some way and I noticed the clutch no longer slips... I started the car in 1st and 2nd and theres no slippage in ether gear no matter how hard I accelerate. Before this all happened, the clutch slipped noticeably in every gear. My problem with the clutch pedal not returning or building any pressure persists however.
Anyone ever seen this happen bwfore?
lopezchris21
25
Nov 19, 2023 08:24 PM
Cypher0117
16
Dec 9, 2009 08:36 AM
old_school_dohcvtec
Oct 4, 2007 09:47 AM
litterbox
11
Sep 2, 2005 04:40 AM
93civcx
Jun 18, 2004 06:25 AM
