Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
08 Accord maintenance question
Old May 27, 2024 | 03:11 PM
GIacona's Avatar
5 Year Member
Default 08 Accord maintenance question
I have 140K on my 08 Accord. I changed the timing belt at 98K and the plugs around the same interval. Is there a suggestion on when I should consider doing the belt and plugs again?
I'm also wondering when it comes to fluids such as power steering, brake fluid, and coolant are there maintenance intervals these should be charged, or just keep an eye on the fluid color and change when it's dirty?
Thanks in advance
Old May 27, 2024 | 05:13 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
Default Re: 08 Accord maintenance question
Your car has the Maintenance Minder, but, if you did not use the maintenance minder, then:
105,000 miles or every 7 years for the timing belt.
105,000 miles for spark plugs.
30k for transmission fluid.
60k or 5 years for coolant. (I change every 30k)
Brake fluid every 3 years.
No set interval for power steering fluid; however, I would still replace periodically.
Old May 29, 2024 | 01:59 PM
GIacona's Avatar
5 Year Member
Hey There,
Thanks a bunch for your reply.
Regarding coolant change, do you do a flush every 30K or just a drain and refill? I had my radiator go at 98K and never changed coolant up to that point. I think changing every 60K or 5 years would be a good preventive measure.
Thanks
Old May 29, 2024 | 04:29 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
I just drain and fill coolant at regular intervals.
BiglyDuck
Honda Accord 2018- Current
Jun 30, 2023 12:25 PM
compscience007
Aug 16, 2017 01:35 PM
mygti02
Nov 29, 2009 08:07 PM
stevescivic
Apr 15, 2008 11:46 AM
