Civic EP3 A/C compressor does not work
Old May 21, 2024 | 09:08 AM
joseandres04's Avatar
Icon5 Civic EP3 A/C compressor does not work
Hello everyone, I was wondering if someone can help me with my issue, few days ago my a/c compressor stops working, looking in my fuse box fuse 1 was melted, I clean that check voltage and put a new fuse. However, the a/c compressor still not working I do all the test if bring voltage to the compressor relay and they engage and works perfectly. When I press the ac bottom, both fans came in, and the blower also works, I test the pressure valve and bypassing it, now, I know that the issue came with the positive that need to activate the relay to activate, I was following this wiring diagram.
Also, Idk if bypassing the relay we can test that the thermal protector is good or bad.
Thanks for the help
Old May 21, 2024 | 07:53 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Civic EP3 A/C compressor does not work
The thermal circuit is a COMMON problem on "K" series applications... have you tried running cold water from a hose over the compressor while the engine is running and the A/C system is "On" to see if the compressor locks up ?
Old May 22, 2024 | 08:31 AM
Hello thanks for the reply I just try that, but the compressor does not lock up
Old May 22, 2024 | 09:04 PM
JRCivic1's Avatar
10 Year Member
Community Builder
I wonder if there is a way to bypass the thermal switch... maybe cut the energizing wire from the thermal switch and connect the blue/red wire to it for clutch lock up... if the compressor engages, then you know the thermal switch is the issue. If there is still no clutch lock-up, the compressor is trash.
Old May 23, 2024 | 11:32 AM
That's weird because the red cable from the ECU E18 is the in charged to energize the relay to give the pass of that voltage, only when I do manually the A/C clutch engaged and works well, so in that case we can discard that the thermal switch is god, or not?
nickitt
Honda Civic (2001 - 2005)
Jul 8, 2019 04:38 PM
mugen94
Aug 3, 2015 02:35 AM
texas6023
Jul 18, 2014 10:07 AM
schueytenten
Sep 11, 2010 03:14 PM
totsie7944
Jun 18, 2009 10:25 PM
