Honda Accord 2018- Current This is the place to discuss all things Honda Accord related for the 2018- Current model year
Heating and cooling
Old May 13, 2024 | 05:56 PM
J288's Avatar
Default Heating and cooling
Took it to the dealership four times coolant is full no leaking from anywhere only happens when I drive above 60km/h but keeps popping that engine is over heating
Old May 29, 2024 | 01:15 PM
quickhondaz's Avatar
Default Re: Heating and cooling
it's likely that the electric water pump has failed. Have had quite a few of the hybrids in lately for that reason. If the dealer is testing the electric water pump through the HDS it will most likely pass, but the impeller shaft is probably sticking at times causing the impeller to not turn at all.
the electric water pump on these are fairly easy to remove. pay them to remove it and check the shaft free-play. That will most likely solve your issue.
Old Jun 21, 2024 | 03:19 PM
eag9314's Avatar
Could be two things; 1) first try the simplest fix and it is to change the thermostat (make sure you buy the correct one with the same temperature threshold) or 2) if the thermostat wasn't the problem, then it might be that your water pump is either in the process of failing or has failed, which regardless will require replacement.
richrd0001
May 7, 2015 09:29 AM
KidZr0
19
Sep 1, 2011 01:28 PM
miksew
24
Oct 19, 2006 08:05 PM
tallyBanned
Aug 18, 2006 08:50 AM
EngineNoO9
Honda Motorcycles
15
Dec 24, 2005 11:54 AM
