Civic ED6 Fuel hardline leak
Old Apr 28, 2024 | 02:39 AM
Chrsb's Avatar
Default Civic ED6 Fuel hardline leak
Hello,
I have a bit of a messy situation, I have a few rusted fuel lines, where as one of them are leaking pretty bad. I'm not quite sure which line this is, but its an 8mm hardline. What would the easiest fix for this be? And what kind of line is this, is it the return?
Thanks,
Chrsb
Old May 2, 2024 | 01:21 PM
Maxcapacity's Avatar
Default Re: Civic ED6 Fuel hardline leak
It's the fuel feed line that gets pressurized.
If you do find a used line to replace it with, the round 90deg connector is different thread size I heard from the '88 vs '89-91..
Old May 23, 2024 | 05:54 AM
90HFSurvivor's Avatar
I just had this same issue. Unfortunately, that line is discontinued. I cut that connection out, got a 3/8" fuel injector hose and straight lined it. On the larger metal line, I had to use a lube and force it on. I then heated the hose and pushed it the rest of the way on to a secure position. Put some hose clamps on each end and it held fine. I've been driving it a week without any issues.
EK9r!der
18
Aug 23, 2012 09:57 PM
juniestyle
Feb 26, 2007 07:34 PM
TeamCracka
Nov 10, 2005 09:28 AM
soon2b
Apr 15, 2005 02:02 PM
Salvatiosix
Feb 21, 2004 08:41 AM
