No spark no ground to distributor
[QUOTE]I have a 93 Honda del sol s, my car started to die out on me and it took longer and longer to start I changed the spark plugs and distributor in an attempt to solve my problem after some thorough research and the use of prodemand I had come to the conclusion that my ecu had failed. I took it apart to see if there was any kind of damage and to smell if it was burnt but there were no obvious signs. My check engine light was on but I was unable to get any codes, once my new ecu arrived I plugged it in and sure enough it started like new
