Car leaking oil and overheating
So i have a 1998 honda accord lx with 202,000 miles. Its leaking oil from the main rear seal and one other place near it on the transmission and it will burn through the oil when im on the highway causing the oil light to flicker and overheat right when i get off the highway. It will also over heat if im using the A/C for a long period of time. What could be the cause or causes of this issue?
It could be multiple issues.
Engine oil is used for part of the cooling system, so if you are loosing enough oil that it doesn't show on the dipstick, this can certainly cause the car to overheat. Conventional oil will leak slower than synthetics through a seal, but only by a little bit. You could also try going to a 10W30 to slow down the leak until you get it fixed.
As far a overheating, be sure that the cooling fan is coming on. With the AC both cooling fans should be working. If you have been using tap or especially well water in the radiator,, it can cause blockages in the radiator cooling fins, adding to the overheating issue. Also a 2-+ year old radiator can be getting clogged. Take off the radiator cap with a cold engine and see if there is any mineral build up in the radiator.
Other causes would be a radiator cap that is not holding pressure as well as a pinhole in a heater hose or a hose that goes up to the intake manifold etc. Too much water or too much antifreeze ratio can cause overheating. Radiator fluid testers are cheap at any parts store and often in a Walmart.
While driving down the road, a car runs cooler s the air is moving across the radiator fins, keeping the car cooler. When you stop (pull off the highway) there is a lot less airflow, allowing for more heat. Also be sure that the radiator is not caked with mud or bugs or too many fins crushed as this also makes it harder to cool the water.
I agree with the cooling system advice. no leaks, good condition coolant, right mix ratio, free of flow restrictions, no trapped air pockets, fan(s) come on when they should, air moves across it freely.
OP, when the A/C is on it's adding heat to the air that moves through the radiator as well as load on the engine to turn the compressor. Both of these systems you have suggested are already being overtaxed. don't run the A/C until you have this resolved. My suggestion is to top up the oil and coolant and drive the car to a shop to have it thoroughly inspected so you have the full picture of the leaks and anything else you'll need to make a good decision on what to do long term.
At one point my volvo was literally pissing oil from the rear main seal, like.... a quart or more every 2 hours of highway driving, and even so I still had no oil pressure or overheating issues.
Sounds like you have a bad leak, but but once there is enough oil on the dipstick i wont stress that, and it shouldnt affect your oil pressure light unless you have some major other issue going on, or whether it is the oil pressure sender unit itself thats doing the leaking
Check through your cooling system, change the radiator cap regardless as cheap insurance, make sure the thermostat is good (lots of youtube videos on how to) and MAKE SURE you keep the oil and coolant topped up until you figure it out.
Using a higher viscosity oil or one of those high mileage oils will slow the leak just a tiny bit, for example a 10-40 high mileage oil, but that is just a band aid, wont fix the fundamental leak
Paradise Racing
35
Aug 9, 2016 12:49 PM
njfastlife
12
Nov 28, 2015 05:54 PM
roastbeefmike
19
Apr 17, 2012 12:05 PM
