Aem wide band Honda tuning suite logging issue
Okay so I sold my wideband that was originally in the car to a buddy with a different car. I bought a new aem x series wideband(I like the ease) The ecu I'm using is a p06 with vtec and a bm emulator. The emulator hasn't been the issue since it worked before. Now I have my settings correct as well they are aem new for the voltages for the wideband and I have red(positive), black(negative) and white(+signal) the signal I have at d14 Becuase honestly if your wide open throttle at 16+afr that's not good so I'm not worried about the full 5 Volts.but my wide band unit in the dash will sit at 10. 6-11.5 at idle if j change that to 14 or anything close to 13 it will misfire but my laptop running hts will read a constant 3.75 volts maxing out the d14 pin voltage for 02 and will not update any tables. What the hell should I do, I'm losing faith
