K24z3 into a ek
I have questions. I have a k24z3 sitting around and want to put it into my EK. I know crank sensor location isn’t useable and am ok with buying a different timing cover to compensate. I’m wondering what sensors to use/tone ring , harness will be 02-04 rsx along with ecu/kpro. If someone could chime in on what sensors I need to use that would help a lot! I’m going to run a drive by cable throttle body with it aswell.
The Z timing cover isn't the same shape as the old K series covers. You can't simply swap the cover for another factory cover.
Good news though. The miata boys make a cover for the Z that allows the use of the older style crank sensor. $$$$
https://kpower.industries/collection...ng-chain-cover
At that point with the price of Hondata and a good RSX ECU you might as well go standalone.
I did find a timing cover to convert the z engine to the old style crank sensor location. My main concern is what engine sensors to use. I already have a 02-04 rsx ecu with k pro and a 02-04 rsx harness. Im only really unsure if all the z3 sensors are compatible and which crank sensor to use and which tone ring to use for the crank sensor.
MidwestSi
18
Mar 26, 2008 10:32 AM
