Honda Civic (2016 - Current) 10th Generation Civic Forum Civic / Si / Type-R Discussions
Sponsored by: CARiD
2017 Civic Sport - P0301, P0304, P0300
Old Jan 11, 2024 | 08:20 AM
Plinny's Avatar
Icon5 2017 Civic Sport - P0301, P0304, P0300
Hey everyone,
Having some trouble with a 2017 Civic Sport 4 Cyl 1.5L (Manual) today.
It's been cold here, and we had a mini snowstorm last night. Went to start and warm up the civic this morning and had the following issues initially.
- Slow Start
- Low, unsteady idle.
- No Throttle Response
- Stall after roughly 10-15 seconds
After the initial stall, dashboard showed the following warning lights
- Check engine
- Brake System
- Power Steering
- Traction Control
On repeated start-up attempts, there was an even lower idle and faster stalling with zero throttle response.
After roughly 5 minutes of attempts, there was eventually a throttle response, with an improved idle (still not steady however) and no stall. Shut the engine down, tried again, died wont start at all.
Pulled the codes the next day
P0301, P0304, P0300
I got some misfires and replaced the spark plugs, but no joy. Here is how the car sounds now.
https://www.dropbox.com/scl/fi/lvbfa...th26lkjlu&dl=0
https://www.dropbox.com/scl/fi/7b76j...lo43schyf&dl=0
- No prior issue of any kind with the Civic
- 43k miles
- filled up the tank full the day prior.
What should I be looking at next? Thanks!
EDIT:
I swapped coil positions and rechecked the codes, still erroring on the same cylinders.
Tommyz
Sep 7, 2021 01:41 PM
Nic0807
Honda Civic (2001 - 2005)
Aug 30, 2018 07:34 PM
hdvolksda91
Jun 11, 2010 05:54 AM
drox
Nov 25, 2007 12:37 PM
b20integrapower
Jan 24, 2006 02:03 PM
