93 Civic, cold start everytime, idles at 1500RPM
So my Civic is cold starting everytime i start it, even when its warmed up. and idles at 1500RPM. so what should i be looking for ? thanks Chris
Re: 93 Civic, cold start everytime, idles at 1500RPM
does your throttle body have a fitv? if so, it may be causing your high idle.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
IACV (Idle Air Control Valve) Could be the problem. Sometimes you can take it off and clean it out and it will work fine.
thanks for the tips. I figured out it was my throttle body sticking. i took it apart and cleaned it once before. if i lift up on the gas peddle it comes down to the right idle. i have a new one TB i just got to put it on, thanks again.
Carpoollane
09-08-2018 03:08 AM
heinrichranches
10-19-2015 08:57 PM
jefe
13
01-11-2011 09:21 AM
