FuelTech and IACV
Old Nov 27, 2023 | 07:35 AM
99pearlude's Avatar
Default FuelTech and IACV
Hello All,
I am running a FT450 and I'm trying to solve my idle control issue. My IACV is still plugged into my factory ECU, can it still control idle or do I need to wire it into the fuel tech? If so, what outputs on the FT would I use? Frequency control output? I only have gray outputs left. Any suggestion to get me in the right direction would be greatly appreciated. Thanks!
Some of my options for outputs
Old Nov 27, 2023 | 07:51 AM
99pearlude's Avatar
Default Re: FuelTech and IACV
I got in touch with FuelTech and they said it would have to be a blue output. I will have to move my wastegate (blue output) to a gray wire to open up a blue output. See pics below.
Old Jun 9, 2024 | 05:28 AM
Ashok46's Avatar
What was the setting you used to get it to work. I have 2 pin IACV and settings are at 250 frequency and it's not moving . Did a battery test it moves.
Old Jun 10, 2024 | 04:45 AM
99pearlude's Avatar
I ended up needing the blue output for something else. The IACV isn't necessarily needed. I'm controlling idle with the fuel and ignition tables.
Old Jun 11, 2024 | 08:45 AM
Ashok46's Avatar
Last question. Do the 2 pin in the IACV have Continuity. Because the one I got has.
I have attached the IACV I have bought.
Old Jun 11, 2024 | 12:27 PM
spAdam's Avatar
Loved
Community Favorite
It's a coil-based solenoid so yes, a basic resistance test will show continuity.
Old Jun 13, 2024 | 09:41 AM
Ashok46's Avatar
@spAdam Could you clear off ur old msgs not able to send you a text.
I am using a Fueltech FT450 have put I a few setting for the PWM. Could let me know if anything is wrong or where to start off from.
Old Jun 14, 2024 | 08:10 AM
spAdam's Avatar
Loved
Community Favorite
The settings you have in your snips look like a reasonable starting point. Let the help file be your guide for tuning your ecu. Most ecu companies these days have really good documentation.
Old Jun 14, 2024 | 10:42 AM
theYBLEGAL's Avatar
Loved
Think about it like this, the frequency is the number of times per second it will allow you to make a voltage pulse. The percentage value should be considered a duty cycle, the length of the voltage on-time per pulse. You may need to raise those %s up to get the valve to respond. A combination of duty cycle and frequency will cause the coil to hold the plunger in just the right place.
Old Jan 7, 2025 | 10:15 AM
monchimonch's Avatar
could you give us a run down on how your set up for idle contro is set
ALL-MTR-LSR
Honda Motorcycles
16
Feb 7, 2007 08:52 PM
JDMkidGSR
Nov 15, 2005 04:59 AM
2fcknfst
Oct 3, 2001 03:40 PM
