Inovate LC2 wideband with HTS issue
Old Nov 25, 2023 | 10:40 AM
blue6gen's Avatar
Default Inovate LC2 wideband with HTS issue
Got a P28 socketed with Cobra RTP in a 94 accord lx. I am attempting to run the Brown wire (0 - 1v) to the D14 pin on the ECU and separately log the yellow wire (0 -5v) on the Cobra. Car will not run right at all with the inovate wideband. Im thinking i nerd to adjust the output scale of my wideband in order to do this. Even downloaded LM programer and Logworks and still can't figure out how to change it. If i can get some insight on this hopefully i can just adjust the 5v output to a max of 3.8v to run it to the D14 pin and adjust the wideband settings in HTS as well.
Would an AEM unit be easier to work with possibly?
Old Nov 25, 2023 | 11:41 AM
RollingRoadEFI's Avatar
Default Re: Inovate LC2 wideband with HTS issue
That question would be best asked to the HTS Discord. The developers are in there and can assist you without wasting time.
I am getting the AEM CANBUS wideband integrated into HTS soon, I sent them one for reverse engineering. Although that probably doesn't help you because you're running OBD I
Old Nov 25, 2023 | 01:18 PM
blue6gen's Avatar
Gotcha.
Old Nov 25, 2023 | 02:35 PM
blue6gen's Avatar
OK so I deleted and reinstalled LM programmer and I finally got into changing the 0-5v output values. Changed the settings in HTS and now I have the signal running to pin d14 and car is running way better.
2000ekd16
Engine Management and Tuning
12
Mar 31, 2014 11:30 AM
BROKE.eg
Aug 5, 2005 05:02 PM
iiilgsrlll
Sep 25, 2004 11:49 PM
streetstylenperformance
Feb 22, 2004 09:37 PM
vx_hatch
Aug 8, 2003 02:59 PM
