Honda CR-V & Element 2WD & 4WD Element & CR-V
2001 Honda CRV - LED dome lights & map light project
Old Oct 14, 2023 | 07:29 AM
k.yepes's Avatar
5 Year Member
Default 2001 Honda CRV - LED dome lights & map light project
I converted the dome lights and map lights to LED. Much brighter than stock. I made my own boards and used 5050 LED chips.
step 1 remove from vehicle
step 2, trace a cardboard cutout that will fit
step 3, scan the cutout into CAD, and use a ruler for calibration.
step 4, add your necessary features
step 5- print out your CAD, and check it. Make necessary adjustments. Rinse and repeat...
Once you get a good working design that you have confidence in, add your electrical parts to the design.
step 6 Convert your components to traces - I "mirror" image it because I print on a special paper that allows me to invert it as I heat press it onto copper clad
Old Oct 14, 2023 | 07:34 AM
k.yepes's Avatar
5 Year Member
Default Re: 2001 Honda CRV - LED dome lights & map light project
i print out my designs backwards on a special paper after prepping my copper clad
step 7 - I use a heatpress to transfer the toner to the boards
after a successful heat press transfer
step 8 - I use a 3:1 ratio of hydrogen peroxide and muriatic acid to etch the boards. The solution eats all the copper that isn't protected by the toner.
step 9 - I cut out the boards with a band saw, and do all of my machining work. After I have good results I wipe off the toner with laquer thinner
step 10 - I chemically change the copper to tin, with a solution called "liquid tin". This helps protect the boards and the components solder on easier
Old Oct 14, 2023 | 07:37 AM
k.yepes's Avatar
5 Year Member
step 11 - adding the LEDs and resistors
step 12 - install and enjoy
Here I made a bracket for the map light PCBs so it can mount onto a flat surface. I designed this in CAD and I 3D printed on high temp ABS
othello
13
Feb 8, 2021 10:09 AM
dumafit
Lighting
Mar 13, 2012 09:01 AM
Turbo Dan
Lighting
Jul 28, 2011 06:02 PM
lak8
Lighting
13
Feb 19, 2008 02:46 PM
OneThirtyEight
Nov 15, 2001 04:56 PM
