Lighting HID/Xenon kits, Retrofits and Associated Topics
Map light LED issues - resistor needed?
Old Jul 28, 2011 | 05:50 PM
Turbo Dan's Avatar
Default Map light LED issues - resistor needed?
The two sides of the map light are configured in parallel.
But, when I install LED festoon bulbs in each side, only one side lights up.
I put them both in and one didn't work, I thought it was burnt out or something.
So I took them both out and only put in the one on the side that wasn't working and it worked, but only one side works at a time. I can't turn both switches on and have both lights on, only one.
Here is how it's wired from behind:
any ideas? do I need a resistor?
Old Jul 28, 2011 | 06:02 PM
Blazin Si's Avatar
Loved
Community Favorite
Default Re: Map light LED issues - resistor needed?
Resistors limit current, so that's not the problem. Do you have the polarity correct when you're installing them? LED's have a positive and negative side. My map and dome lights are controlled from a switching ground. Is that how yours is connected?It probably is, but I can't tell from the photo.
EDIT: Can you take a shot from directly above the rear of the housing and also take a photo of the LED's you're using?
MrLeWayne
Audio / Security / Video
Nov 21, 2010 12:46 PM
Blackknight103
Honda Civic (2006 - 2015)
May 15, 2008 09:31 PM
lak8
Lighting
Feb 1, 2008 09:28 PM
seacilian
Lighting
Jan 26, 2008 01:23 PM
OneThirtyEight
Nov 15, 2001 04:56 PM
