Honda CR-V & Element 2WD & 4WD Element & CR-V
Need Advice On 2002 CR-V Wiper Arms
Old Oct 10, 2023 | 05:47 AM
CR-V Guy's Avatar
5 Year Member
Default Need Advice On 2002 CR-V Wiper Arms
Something is wrong with the linkage on my CR-V wiper arms. Sometimes the driver's side wiper hits on the left side of the window trim (thud!) before it goes the other direction and sometimes the passenger side wiper hits the drain cowl (thud!) before it goes the other direction.
When I grab either wiper I can put a little force on it and move both arms together…almost like there is slop or a worn spline somewhere in the mechanism.
Any suggestions on where to start troubleshooting? I've had at least a few Hondas over the years but never had a problem with the wipers.
If my description above isn't accurate then I can post a short video.
Thanks in advance for any help.
Old Oct 10, 2023 | 06:14 AM
starchland's Avatar
Default Re: Need Advice On 2002 CR-V Wiper Arms
Sounds like a bad linkage bushing
Old Oct 10, 2023 | 08:14 AM
CR-V Guy's Avatar
5 Year Member
starchland, is that a serviceable part or does the linkage itself need to be replaced?
Old Oct 10, 2023 | 04:39 PM
Ryanthegreat1's Avatar
Have to replace the links. Replace them both and all the rubber seals.
Might be cheaper to buy the whole transmission assembly.
Old Oct 11, 2023 | 03:47 AM
CR-V Guy's Avatar
5 Year Member
Is this a common problem? Have either of you had this on your own vehicles?
Old Oct 11, 2023 | 05:29 AM
Extremely common. Both of my elements and my wagon wore out the bushings
Old Oct 12, 2023 | 04:52 AM
CR-V Guy's Avatar
5 Year Member
I attached an exploded view pdf of the wiper linkage assembly. Which parts are the suspected culprits?
Old Oct 13, 2023 | 05:28 AM
CR-V Guy's Avatar
5 Year Member
Bump...hoping one of you can point me in the right direction here by tell me which parts are most likely the culprits. 👍
Old Oct 13, 2023 | 05:49 AM
starchland's Avatar
It’s already been mentioned Nobody can tell you exactly definitively what it is. Take it apart and see
Old Oct 13, 2023 | 05:56 AM
CR-V Guy's Avatar
5 Year Member
I agree 100%...was just wondering if you two would give me a head start by telling me which parts "commonly" fail. Specifically which item(s) on the diagram are the "links" that Ryan mentioned above. You two, starchland and Ryan, have been a huge help to me in the past and I appreciate you both! 👍👍
Old Oct 13, 2023 | 11:16 AM
Part 10 and 11 are the links that have the bushings that wear out and are not serviceable. It's nylon cast into the aluminum rod end.
You will want all the rubber seals too. 8 and two of 7.
Usually part 9 for the whole transmission assembly ends up being cheaper and you don't have to mess with rebuilding what you have.
Old Oct 16, 2023 | 04:25 AM
CR-V Guy's Avatar
5 Year Member
Thank-you both for the feedback, you two have been a huge help not only for this post but for other questions I have posted at honda-tech. I got a quote from the dealer and pricing doesn't look too bad so now I just need to take it apart and inspect the parts.
Old Aug 6, 2024 | 09:42 AM
CR-V Guy's Avatar
5 Year Member
Past due update: the wiper linkage joints were bad just as described above. I replaced both arms (#10 and #11) as well as the rubber seals (#7 & #8).
BradleBo
Nov 22, 2018 09:26 AM
Tyte-S
Feb 17, 2014 09:09 PM
KiDDD...
25
Feb 7, 2014 09:27 PM
Mavrick
11
Dec 1, 2006 08:34 AM
