Honda CR-V & Element 2WD & 4WD Element & CR-V
Knock sensor - resistance and voltage output?
Old Sep 23, 2023 | 02:32 AM
allyballybee's Avatar
Icon5 Knock sensor - resistance and voltage output?
I have a 2005 petrol CRV with the P0325 knock sensor code. I have replaced the KS once already but the CEL returns after half a mile of driving. I stupidly threw away the original KS after fitting the first new one.
So I bought another replacement and did some basic tests on the new unit before fitting it. The new one I am testing is Febi/Blueprint part from a reputable local motor factor.
Resistance - shows open circuit - my meter reads to 50 Mega Ohms
I have seen various values quoted for resistance and several posts saying if it is open circuit the KS is bad?
Voltage - mount the KS in a vice and tap the vice - 20 mV when tapped
Waveform - check the waveform with scope but while the scope shows a ping in the voltage when the KS is tapped not accurate enough (not a storage scope) to tell much about shape of waveform.
I contrast these results with two YT videos.
at 2:20 in seems to be getting 5v out his sensor, testing it off the vehicle, same as me.
As is this video
About 5 minutes in he too gets 4/5v out of the sensor while tapping it.
Does anyone know the values - I 'should' be getting.
Thanks for reading.
abb
DeCoY
Jan 4, 2020 06:19 AM
Custard
Oct 5, 2019 10:40 AM
SuperBowser707
Dec 4, 2012 07:49 AM
rocket256
Jul 12, 2004 11:45 AM
