Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Engine and ECU swap help
Old Aug 23, 2023 | 08:56 AM
CarGuy2010's Avatar
Default Engine and ECU swap help
Hi everyone, I own a 2003 Civic EX Auto trans 1.7L VTEC D17A2. I recently picked up a 2002 Civic LX Manual trans 1.7L NON-VTEC D17A1.
For reasons not important to this topic I had to swap the good (D17A2) engine from the 03 Civic into the 02 Civic. I did not swap the transmission
of course, because I wanted the manual trans. So what I did swap was the engine/head, ECU, and ignition. And I ran the wires from the VTEC solenoid
and the EGR valve to the ECU so all of that would work. But now the problem as expected is that I am getting 4 trouble codes and a check engine light
related to the transmission:
P1706 A/T Gear No Position
P1773 Clutch Pressure Control Solenoid Valve B Failure
P1768 Clutch Pressure Control (linear) Solenoid Valve A Failure
P1753 A/T Lockup Sol A Failure
So I am trying to figure out a way around this. The 02 CIvic was a manual trans so it did not have the connector C to plug into the ECU like the Auto trans
car had which is why I am getting all of these codes. Is there an ECU that exists for a manual and VTEC 02-03 Civic? That is what I am trying to find out.
Or is there another way around this that anyone knows of? Can I modify the ECU? Can I take the Auto trans part of the harness out of the 03 Civic and
plug that and all of those sensors into the ECU? LOL. Any advice would be welcome. Thank you!
Old Aug 23, 2023 | 11:01 AM
CarGuy2010's Avatar
Default Re: Engine and ECU swap help
Also, let me follow that up by saying the car is drivable in this state, all the shifts and everything works as it should. But I live in Atlanta, GA and I have to pass emissions to be
able to register the car and drive it legally. To pass emissions there can be no check engine light.
Old Aug 23, 2023 | 07:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
All you need to do is get an '02-03 EX manual ECU and plug it in, marry it to the immobilizer and key, and you will be good to go.
Old Aug 24, 2023 | 06:10 AM
CarGuy2010's Avatar
JRCivic1, thank you so much for the reply! I mean that is a very simple answer but makes sense. I was not sure if there was a 02-03 EX manual ECU that was also VTEC tbh.
Do you know what the part number for that ECU would be so I can make sure to get the correct one?
Old Aug 24, 2023 | 01:03 PM
CarGuy2010's Avatar
Would this be the correct part number 37820-PLR-A03
It says its for a 01-02 Honda Civic EX 1.7L
Would that be the correct part number for a VTEC?
Old Aug 24, 2023 | 08:44 PM
JRCivic1's Avatar
10 Year Member
Community Builder
It says its for a
Yes, that part number will work. Your last two posts on this thread have been typed in a light grey font color and are VERY difficult to read... could you please change back to BLACK so future posts are easy to read ???
Old Aug 25, 2023 | 05:30 AM
CarGuy2010's Avatar
JRCivic1, thank you so much for your reply. I will give it a try and follow up. Thanks for the heads up about the font color, I use (Dark Reader) extension for dark mode, so I could not tell my font was gray, sorry about that.
civiclover97
Feb 6, 2023 08:50 AM
chrissychris
Nov 8, 2022 01:54 PM
Kamilsamek
Jul 25, 2018 05:58 AM
A Username
Jul 3, 2017 09:09 AM
akouznet
May 24, 2009 06:50 PM
