Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Help finding CEL without a dashboard
Old Aug 14, 2023 | 02:27 PM
Dirt car racer's Avatar
Default Help finding CEL without a dashboard
So I’m able to jump the blue connector of the OB1 but I don’t have a dash board. My question is where on the fuse panel or equivalent would I be able to wire in a light to see my codes. 1993 Accord. F22A6. Thanks!
Last edited by Dirt car racer; Aug 14, 2023 at 02:29 PM. Reason: Changing the title
Old Aug 14, 2023 | 08:25 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Help finding CEL without a dashboard
The wire coming from A13 at the ECU is the MIL light. I just can't remember if it is power or ground, so I am unsure what the other wire on your bulb would need to go to.
Old Aug 15, 2023 | 09:30 AM
Relic1's Avatar
the ECU provides ground, the other side of the light needs to be connected to battery.
OP, it's a simple light, even a 12v LED works fine. It can be mounted anywhere you have available, next to a switch for the service jumper ideally.
Old Aug 15, 2023 | 02:04 PM
Dammit….should have mentioned this earlier but just remembered I have an ECU from a 1993 prelude. Same engine family so I would assume the pin outs should be the same.
Old Aug 15, 2023 | 02:14 PM
tech8's Avatar
Global Moderator
Loved
Community Favorite
1993 Prelude is also at pin A13.
Old Aug 15, 2023 | 02:56 PM
Amazing. Thanks for the help everyone!
Old Aug 17, 2023 | 12:57 PM
Last question….maybe. I have a battery disconnect switch that shuts off power to the ECU. Essentially the whole car. So when I power it back up I assume the codes are all reset? If that’s the case do you recommend running a wire direct to A25 from the positive terminal of the battery? Any other suggestions. Thanks.
arnworx
Mar 10, 2022 04:09 PM
Smith_ek
Jan 6, 2008 04:39 PM
yoshio006
May 22, 2005 06:49 PM
Evilducky
Aug 15, 2004 11:26 PM
