Ek B swap Wiring
Old Jul 30, 2023 | 02:44 PM
mvdokh's Avatar
Default Ek B swap Wiring
Hi all, this is my first time posting to hondatech. I have a 96 civic cx hatch with a 96 b18b1. I bought a wiring harness off ebay for obd2 and the ecu side plugs are obd1. In the description it states that it did not come with the shock tower plugs, which on the ek, it is part of the full harness. What should i do about this, and what is the function of the shock tower plug. The harness also didn’t come with a power steering pressure switch plug, is there a way for me to retain that? Also, near the ecu there is a green plug for the chassis, i believe it’s for obd2. On the new harness there is a 20 pin plug that doesn’t fit onto it. Can I just leave it hanging?
Old Jul 30, 2023 | 07:01 PM
zerovandez's Avatar
Default Re: Ek B swap Wiring
When I swapped a B18b into my ek decades ago - I dont recall purchasing an engine harness. I just jused my D16y7 engine harness and may have extended a few plugs. It was direct plug and play after that.
Sounds like you purchased an integra engine harness which will not natively work in a 97-00 civic chassis.
Old Aug 10, 2023 | 06:02 PM
mvdokh's Avatar
you were correct. I had to use a civic harness since it’s one piece instead of the integra 2 piece harness
v8killaz
May 15, 2010 03:07 PM
ja20_eg
Feb 9, 2009 06:10 PM
.Hookedonhatch.
Oct 2, 2007 02:34 PM
Greasemonkey
12
Apr 13, 2004 10:03 AM
Powered by Honda
Oct 12, 2001 09:30 AM
