H22a4 ek civic need help BAD
Hey Honda forum pretty new to the honda community and car community in general but been at this swap from over a year now I had it running at one point but after I did the ckf mod to get ride of code 9 CYP cylinder position it won’t start. anyway
It’s a h22a4 with a garret turbo, rdx 410 injectors, p28 s300, using the stock dx harness with a obd2 to obd1 jumper harness. I’m using the obd1 prelude dizzy with a another jumper harness from obd1 to obd2 this time, I did the ckf mod but I cut the tdc and crank position, because i had a cel for TDC and Cps plus cyp. I wired TDC and cps to the sensor on the oil pump and both codes went away but now it only cranks and sputters and sounds like it’s about to start but doesn’t I’ve search the forms over and over and maybe I’ve missed the right one but if anyone has answer I would greatly appreciate it, if I missed anything and you have a question I’ll answer it the best I can.
mugenEJ1_777
Jul 21, 2009 09:17 AM
danxdan
Jun 9, 2005 04:46 PM
