Larger Brake Pistons 46mm vs. 38mm/43mm Effects??
Right now i am running Legend GS 2 piston calipers on an Integra. They are dual piston one is 38 mm other piston is 43 mm. If i went to a caliper that had dual pistons but with 46 mm pistons what would be the overall effect?
When i first did this upgrade to Legend GS calipers and stainless steel brake lines i noticed a huge difference in stopping power being able to stop sooner with the same amount of force applied to the pedal (compared to stock GSR braking capabilities).
