97 ITR Rough and High Idle After IACV Replacement
Old May 24, 2023 | 09:01 PM
dragonxx21's Avatar
Default 97 ITR Rough and High Idle After IACV Replacement
Recently tried to replace my IACV with an aftermarket one to see if it would help with my car surging during idle and it ended up giving me an even worse surging issue once installed. Car would originally surge from around 1200-1500 RPM during idle, but with the new IACV installed it was surging from 1500-3000 RPM during idle. Took it off and compared it to the original IACV installed on my car and noticed that the valve on the new part seemed to rattle when shaken whereas there was no rattling at all on my older one. Ended up trying to clean out my original IACV with some brake cleaner and reinstalling it and it seems a little better but still fluctuates a little bit. Is it normal for IACVs to rattle when shaken or did I just get a dead part. Is there any way to tell for sure if the idling issue is being caused by the IACV or if it could be something else? I have tried disconnecting the IACV connector while the engine is running and it seemed to go down in RPM but stay steady, which made me think it was an IACV issue in the first place.
Old Jun 1, 2023 | 01:02 AM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: 97 ITR Rough and High Idle After IACV Replacement
Try another one, sometimes you can get a bad one or the incorrect one. Make sure the gasket is new on the IACV,
You can also run some test to see if you have a vacuum leak which will cause the idle to surge.
Old Mar 10, 2024 | 08:45 PM
trilapino's Avatar
I’m going through the same thing. Replaced with another valve and it got worst. Any update?
Old Mar 11, 2024 | 04:18 AM
DC2-ProdUcTiOnS's Avatar
From: Howcome we park on driveways, and drive on parkways?
check for vacuum leaks somewhere in the lines leading to the manifold. Also, try resetting the ecu also so its on a fresh learn cycle when it starts.
dc4b20
22
Dec 3, 2012 09:54 PM
92_JDM
Engine Management and Tuning
Aug 12, 2010 03:23 PM
dc4teg95
Jul 5, 2010 08:09 PM
turbotime
Oct 24, 2005 12:01 PM
DC2*Integra
Sep 20, 2005 12:51 PM
