Suspension & Brakes Theory, alignment, spring rates....
Master Cylinder Channel A&B to Prop Valve Locations
Old May 24, 2023 | 03:49 PM
kaydubbs's Avatar
Default Master Cylinder Channel A&B to Prop Valve Locations
Hello,
I have been searching for a specific brake line question but have not had any luck, hoping someone can help. I have confirmed the ports to each of the 4 calipers, but not the 2 inputs.
Can someone please confirm if it matters which of the 2 non-ABS master cylinder ports (both facing the left fender) go to either of the 2 "inputs" (channel A and B, also called M1 and M2) on a 4040 non-abs prop valve? I understand the fluid gets divided to one front and one opposite rear. For example, does the primary piston MC port closer to the firewall need to go to Channel A, or can it also go to Channel B prop valve?
Some more specifics:
Non-ABS 15/16" master cylinder, OEM number would be 46100-SH4-A11.
Non-ABS 4040 prop valve, OEM number 46210-S04-902.
Thank you!
Del Sol on Steroids
Mar 5, 2008 07:52 PM
herde1724
Aug 11, 2005 11:37 AM
jdm92accord
Jan 31, 2002 08:15 AM
