2002 Accord 3.0 SRS light
Old May 3, 2023 | 04:00 PM
Fitzgr8's Avatar
Default 2002 Accord 3.0 SRS light
I pulled the codes and when I try and reset the SRS system the light goes out but comes back on the next time I start the car. I pulled the codes using pins 5 and 9 and I get 4 quick flashes then 5 and 4 so I'm guessing it's a 5-4 code but I can't seem to find any info on this code.
Old Jan 22, 2024 | 07:44 AM
Wallydock's Avatar
Default Re: 2002 Accord 3.0 SRS light
Old Jan 22, 2024 | 07:47 AM
Wallydock's Avatar
The 5-4 code has to do with the SRS system. From I am reading, it says " internal failure of SRS unit. Check battery system voltage, if voltage is low, repair 12V power or VSS feed circuit prior to troubleshooting SRS."
Argenis 2524
Feb 5, 2016 11:48 PM
aznpreludeSH
Mar 18, 2008 11:30 AM
fijo
Oct 30, 2006 07:53 PM
J T*
Feb 20, 2002 08:16 PM
