Can't figure out this issue with b18c
Old Apr 28, 2023 | 04:11 PM
krispykreem's Avatar
Default Can't figure out this issue with b18c
I have a 98 civic sedan with a b18c and type r p73? Ecu I believe.The car wouldn't crank or start so i replaced the starter, battery, ground wires (transmission main battery valve cover cleaned t stat ground).
​​​​​​Checked all fuses cleaned under battery and ignition fuse to be sure also continuity tested them Car started after slightly crimping starter solenoid connection. Ran it one day to test, on the way back the check engine flashed and it shuttered. Flashed again and the car died and had to coast it to the side of the road. Now it cranks only intermittently and the fuel pump is not priming since it shut down. I have a new ebay pgmfi relay in the car now(replaced as part of troubleshooting from before) and the oem one used to prime the pump but it is also not doing anything. Is my ecu shot? Ignition? I have no idea.
There was no check engine prior to it flashing a couple of times before dying.
Old Apr 28, 2023 | 08:29 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Can't figure out this issue with b18c
Check your engine wiring harness ground at the thermostat housing... make sure the surface is clean, paint free (don't forget the two bolts that hold the thermostat housing to the block... if you painted the block this needs to be scraped and then the thermostat housing torqued back down) and of course, the bolt is tight on the ground wire.
Old Apr 28, 2023 | 08:48 PM
I've cleaned the thermostat ground thoroughly, I will check the housing bolts and maybe even try running a ground wire under the thermostat ground to the chassis, it's confusing how the fuel pump isn't priming all the sudden now.
Old Apr 29, 2023 | 11:37 AM
Inside the ecu it is a p73 looks like some corrosion in the middle of pic left of NEC chip or something i'm not a circuit board expert but if anyone knows what these pathways control where the corrosion is or if it even matters. My fear in replacing this is frying another one so i will have to check for shorts before buying another if that's what possibly caused this or it could be just old age idk . Ever since i put it back in radiator fan spins and still no fuel pump
Old Apr 30, 2023 | 12:37 PM
Removed radiator fan fuse and now pump primes continuously when turned to run not the usual 2 seconds. What could this mean? Im replacing all fuses since they only cost 6 dollars
Old May 3, 2023 | 07:35 AM
Well appears I'm gonna have to fix this myself as I don't know any honda electrical gurus around me. I'll update once I've found the issue.
Old May 3, 2023 | 08:18 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Your problem is a good one... I would be looking at a damaged fuse box or burned wiring in/out of the fuse box.
Anthony Liardo
21
Oct 16, 2017 10:22 PM
hpi247
Oct 20, 2010 03:45 PM
92IntegraPOS
Dec 30, 2008 08:36 AM
ej2civic
11
Jun 20, 2007 05:57 AM
