Starter won't turn over
Old Apr 18, 2023 | 04:08 PM
zacdahwac's Avatar
Default Starter won't turn over (solved)
1997 Honda Civic HX M/T
I was changing my trans but while taking the starter I forgot to unplug the battery, and shorted the starter. After getting done with the trans I put a new starter in and I checked ALL the fuses under the dash and it still won't start. It is not the clutch switch, which I already tried. I thought it was the starter cut relay but I plugged in a the heater motor relay from the engine bay fuse box, but that didn't fix it. I jumped the + terminal to the signal wire on the starter and it works like that, but I don't want to do that every time I go somewhere. Please lmk what it might be, and some other things i could test or relook over.
update: it was my push start conversion kit, i honestly didn't think it would cause a problem, but i was mistaken thank yall for helping me out, very useful info for others
Old Apr 18, 2023 | 05:05 PM
Maxcapacity's Avatar
Default Re: Starter won't turn over
Just double check the #31 7.5 amp starter signal fuse, pull it out and look at it to be sure it didn't blow.
Also check your 40 amp ignition fuse too.
Old Apr 18, 2023 | 05:09 PM
zacdahwac's Avatar
Originally Posted by Maxcapacity
Just double check the #31 7.5 amp starter signal/ICU fuse, pull it out and look at it to be sure it didn't blow.
Also check your ignition fuse too.
i checked all the under dash fuses and engine bay fuses they are good
Old Apr 18, 2023 | 07:58 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
... including the really big "screw in" ones ?
Old Apr 18, 2023 | 08:21 PM
zacdahwac's Avatar
that's included in all i believe
Old Apr 18, 2023 | 10:55 PM
The only last thing it could be I would think is your chassis ground to the tranny is poor..
Make sure your battery is good. Battery terminals clean and tight, no frayed ground wires and all connected to bare metal.
Old Apr 20, 2023 | 06:21 PM
countrynoob's Avatar
From: Whats Up MN!! But still the middle of nowhere...
With the assumption of good fuses, the starter wiring is controlled by the starter cut relay, which is switched on by the clutch switch. If you already jumped the clutch switch and it still doesn't work, I would try jumping the starter cut relay (please test wires). If that still doesn't work, you may have a bad connection somewhere in the wires between the battery positive and the starter cut relay, which could lead to finding out your ignition switch being bad, as the position of your ignition switch supplies power to the circuit to your starter.
Jack Murphy
Jun 21, 2017 06:23 PM
slow_sihatch
16
Aug 4, 2015 04:35 PM
UgandaHonda
Dec 30, 2011 07:04 PM
T:rex
Apr 20, 2009 09:34 AM
verseone
Jul 27, 2002 03:10 PM
