99-00 OEM installed Raybrig fog lights suddenly not working
Old Mar 29, 2023 | 05:24 PM
na96ek4's Avatar
Default 99-00 OEM factory installed Raybrig fog lights suddenly not working
Picked up a really clean 00’ EX sedan a few months back. 100% BONE stock with factory installed raybrig fog lights. Fogs worked when I got the car but just noticed they quit working. I took the bumper off to check for power at the plugs to the lights and confirmed no voltage. The light on the switch is lighting up when turned on. Pictures of the harness I’ve found online show it is plugged into the fuse box in 2-3 places and apparently there is a relay tucked up under there. Is there an inline fuse on that harness that could of popped? Or does it wire up to use a fuse in the under dash fuse box? I’m having a hard time finding what I need to assist in troubleshooting this. Really want to get these fogs lit again 😎
Old Mar 30, 2023 | 04:58 PM
na96ek4's Avatar
Default Re: 99-00 OEM installed Raybrig fog lights suddenly not working
I took of the lower dash panel today and found the 15A inline fuse, that checked out to be ok. I checked to see if I had power at the fuse and I do. I can also hear the relay clicking when I switch the lights on. The ground is nice and clean as well. Im not sure where to test from here
smackdown
Mar 10, 2010 11:48 PM
taimysho0
Jan 17, 2009 06:32 AM
recaroem2
Honda Civic (2001 - 2005)
Nov 5, 2008 01:58 PM
nudvl
17
Mar 29, 2008 10:42 PM
skimeast1982
Audio / Security / Video
Oct 22, 2005 11:33 AM
